rockford fosgate amp with kicker l7
hello, i am having trouble how to wire these subs perfectly. i seen so many pics how to wire but i dont think any of them are right. Here is the amp i have rockford fosgate R1200-1D and these are the 2 subs i have Kicker 11S12L72. I want to wire these subs to max it can support which is 2 ohms.
specs for amp
Code:
Number of Channels: 	1
Rated Power
(RMS Continuous Power): 	400 Watts x 1 @ 4-Ohm
800 Watts x 1 @ 2-Ohm
1200 Watts x 1 @ 1-Ohm
Total Power
(Sum of Rated Power): 	1200 Watts RMS
Dynamic Power
(PVC/PowerCube®): 	499 Watts x 1 @ 4-Ohms 0° Res
898 Watts x 1 @ 2-Ohms 0° Res
1,400 Watts x 1 @ 1-Ohm 0° Res
Bridgeable: 	No
Frequency Response: 	20Hz to 250Hz +/-1dB
Efficiency (average): 	85% @ 4-Ohm
85% @ 2-Ohm
80% @ 1-Ohm
speaker specs
Code:
Size (IN.,CM)
12, 30.5
Impedance (OHMS)
2 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)*
1500/750
Sensitivity (dB 1w/1m)
88.6
Frequency Response (Hz)
20-100
Mounting Depth (IN.,CM)
6-11/16, 16.9
You would only use one set of the terminals on the amp. Use the +- on the same side. Those subs can be wired @ 2 ohm or a 1/2 ohm. That amp does its power @ 1 ohm. For amp's max power, you need d4s.
wouldnt that damage the amp connecting it to one terminal? also what is d4s?
fpresiado
fpresiado
farmersville ca
LosIsATool
