rockford fosgat t165-s?
Clear and crisp I already have a sub so I don't need bass. I am looking for a clean clear sound without having very bright tweeters to hurt my ears like the jbls do
A 5-band parametric EQ or a decent graphic EQ would help tame some of the peaky frequencies you're not enjoying. Also, make sure the button on top of the crossovers is pushed in. If your stock head unit just has a treble adjustment that probably will affect a wide range of frequencies.
I use the eq on my phone its 10 band. Do will I not see a big difference in quality from the jbls to the Rockford's?
i got them for 159.99 on amazon, i just installed them and they do sound pretty good, i love the tweets they are not as bright, i even had them on +2 db, i may drop them down to 0 though. but they seem to have better separation then the jbls and also it sounds more centered, the jbls seemed the voice was more on the right.
i don't like how they had the tweets on connections so i had to cut them off and i really didnt want to do that, and also the connections on the woofer are different then the connectors i had, with these rockfords i had to do a lot of modding. but i may keep them in.
The wire broke off of one of my tweeters. I'll re-use them if I can fix it. But you got a good deal
i had that happen to my JBL's both wires broke off, so i just wrapped the wire around the solder and put electrical tape on it and seemed to work.
bradl79
bradl79
NLR
BlurredVision
