rockford 800a2 question
jeffrich21
i got a good deal on this amp $200 .it is 1997 modle this amp can be bridged at 4 ohms .has any one every ran one with a 2 ohm load and if so how long can run it like that.i have heard of people running a 1.3 ohm load on this amp and it performs great.
rockford fosgate is know for outstanding power amplifiers, but if the amp says 4 ohms you might want to only use a 4 ohms. you could contact rockford fosgate about that they could tell you yea or nea.
I wouldnt give it les than a 4 ohm load , thats 2 ohms with the amp briged , At a 2 ohm load thats 1 ohm brigded not good !
i used to have that amp and i had it bridges all the way down. It heats up and shuts off once in a while. Like a really hot day and after playing it for a while. But it sounds great.
I would not bridge a Rockford amp under 4 ohms. They are notorious for heating up real badly. If you want to keep that amp in good working condition I would not push it that hard....
Just my opinion.
thanks alot for the information.i will not try to bridge under 4 ohms. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif :cool:
thank you
806
The surprise wasn’t that they didn’t offer one…it’s how much engineering went into making it easily replaceable, and then not offering one. Maybe...
Thanks ya. Just pulled the trigger on the 1500BDCP because of the constant power that RF developed to help with the ohm rise.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
jeffrich21
jeffrich21
Spddracer
    May 24, 2024
    May 23, 2024
