Rocford Fosgate T10001 bd power house
Louisiana_CRX
dem shoes......
Rockford Fosgate T10001 bd
Used and works like a champ I just took this out of my Jaguar...a very powerful amp...expect close to 1500rms @ 1ohm...What you see is what you get.....
$250
$20.00 shipped CONUS
Description
CEA-2006 Compliant
Number of Channels 1
Rated Power
(RMS Continuous Power) 500 Watts x 1 @ 4-Ohm
750 Watts x 1 @ 2-Ohm
1000 Watts x 1 @ 1-Ohm
Total Power
(Sum of Rated Power) 1000 Watts RMS
Bridgeable Yes (bd-sync2 cable required)
MasterSync
PowerSync
Crossover Controls Low-Pass (LP): 32-250Hz 24db/octave Butterworth
Infrasonic filter: 27Hz 12db/octave
Tone Controls Bass: 0dB to +18dB @ 35-70Hz
Phase: 0/180 degrees
Signal Input Low level: 1 RCA pair
Signal Output Low level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 1/0 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Fan cooled
Visual Indicators Power On
Thermal Status
Speaker Protection
Circuit Topology Class Class bd
Frequency Response 20Hz to 300Hz +/- 0.5 dB
Shipping Weight 20.8 Lbs.
(9.4 Kg.)
Dimensions (HxWxL) 2.6 x 12.8 x 18 (in)
6.6 x 32.5 x 45.7 (cm)
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
Louisiana_CRX
