Eclipse CD8445 (8 volt HU) , AudioControl Epic-150
sojiaraggs9000
Audio Control Epic-150:
Bass Restoration processor with SPL Display
SPL Display with Microphone Included
Para-BASS EQ
Patented Pass Restoration Circuit
Battery Voltage Indicator
Speaker Level Inputs
Balanced Differential Inputs
Eclipse 8445 8volt head unit
ESN E8 High-Power "Customize" CD/MS Receiver with MP3/WMA playback and Remote This means when reading CDs it reads 60 seconds in advance which eliminates skipping.
CD/CD-R/RW, MP3, WMA playback
MOSFET 50 watts x 4 channel power output
High 8 volt preamp outputs MAD GOOD! 8v preouts let you get louder (quicker) at lower volumes. Very rare! most units are only 2.5 to 5v.
Wireless remote included
3 pairs of preamp outputs (front, rear, and sub)
Circle Surround II Sound
E-iSERV connectivity
Area Shot (basic map, arrow and text)
5-pattern various color illumination
Motion picture display
SIRIUS Satellite Radio Ready (tuner, antenna and subscription required and not included)
Advanced 2-mode Sound Control DSP:
7-band Parametric EQ (advanced mode on)
Speaker Time Alignment (to make the sound always sound centered to your position)
Crossover
Listening Position Selector
Multi-Harmonizer
Source Volume Control
Memory-stick ready for other MP3/WMA playback option
Advanced 24-bit Digital-to-Analog Converter
HD radio-ready (tuner required)
GPS unit-ready (GPS add-on required)
FM/AM Tuner
8-step full dot VF display
MS/CD ESN security
CD Text support
Aux input
- Audio Control Epic-150 - I made up a cigarette lighter hook up for it. Works great I only used this for testing voltage and the SPL difference of a newly built box rated on the 150db SPL meter it has. (How close is the meter to a Termlab? I don't know, never had it tested)
- Eclipse 8445 8volt head unit - It has 4 sets of preamp out puts! REAR , FRONT and NON-FADER. It also has AUX output, CD CHANGER plugin as well as a SIRIUS plugin. Eclipse doesn't make this 8volt head unit any longer!! Comes with harness, manual, remote, mounting hardware, 2 trim rings and an extra faceplate and faceplate ribbon. . Last time I looked these sell for $399.99 new and around $250 on ebay IF you can find them. Considering there discontinued you could be hard pressed to find any on ebay.[/i]
- Audio Control Epic-150 - $150
- Eclipse 8445 8volt head unit - $200 ------ TRADED
*Rather Just trade for an amp haha. But meh w/e works. Just trying to see if I can get anything decent. My little sister need some bass lol. Copy n pasted from my WTT post .. if new pics are needed I take them just let me know
Items Of interest:
. 400+ watt amp. (400+ RMS @ 4 ohm or 1 ohm.)
. 4 Gauge Complete Amp Wire Kit
. A nice Line Out Converter
As long as the place being shipped to isn't too far.. prices above are with shipping included.
Eclipse CD8445 was recently repaired. It had a display issue but that has been takin care of. It works 100% rare 8 volt pre out puts what more can you ask for.
I popped the unit open and found that one of the capacitors broke off some how.
Which I fixed!!
I found the manual and another faceplate trim ring. You also get the extra face plate and faceplate ribbon that I bought. (To fix the original problem but ended up not needing but I switched out anyways.)
Video Of the headunit working 100%
TTT, Eclipse was traded out. Got the AudioControl Epic-150 left.... Trades wise only looking for a pretty nice (possible adjustable) 1 channel Line out converter. And a Complete 4 gauge amp wiring kit.
sojiaraggs9000
sojiaraggs9000
West Tx
disturbed471985
