Robert Zeff ARC Audio 900.6
wanderer1
Item(s) for Sale: discontinued flexible little powerhouse
Item(s) Description/Condition: •Advanced Microprocessor control system
•Code Based flashing diagnostics for faster trouble shooting
•Optional center channel
•2/4/5-6 channel input options and source selection switches
•Block style terminations
•12dB butterworth crossovers (all channels)
•Front + Rear Channels (High pass and Full Range)
•Sub + Sub Bridged on channel 5+6 (Full Range and Low Pass only)
•Center Channel #6 (Full Range and high pass only)
•Power output RMS @ 4 ohms: 4 x 60 watts
•Power output RMS @ 2 ohms: 4 x 100 watts
•Power output RMS @ 4 ohms (Sub Channels only): 2 x 155 watts
•Power output bridged @ 4 ohms 2x120 watts: 2 x 120 watts
•Power output bridged @ 4 ohms (Sub Channels only): 1 x 550 watts
•Transient Distortion:
•Frequency Response: 20Hz - 20 KHz
•Signal to Noise Ratio: >77dB
•Bass Boost: +15dB @ 45Hz
•Crossover (Butterworth): 55Hz-5.5KHz var - 12dB
•Fuse: 25A x 4
•Size: 19 1/2"(L) w 8.0"(W) x 2 3/8" (H)
14 little nicks but actually looks great. Cover is easy to remove to re powder black or custom color
Price: $395 shipped and paypal
N/A
Item Pictures: http://s1297.photobucket.com/user/oldcadguy/media/stereo/DSC_0115_zpsjpjq0dxv.jpg.html List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). [/i]
Run your whole system with this one a amp. Good sonics, lots of options, excellent reliability and high power for the sib if you want. Hard to go wrong with this one for a nice clean simple system.
I pretty much have all I need plus lol. I would entertain a high er end double din Kenwood that was compatible with the new system that would allow me to keep my SYNC in my F-350. 3 new group 65 Odyssey batteries could be worked out. I feel the price to your door is pretty cheap too at $375 but that's relative. PM works better also.
wanderer1
wanderer1
Laughlin
rlmich
