Ring Terminal Distribution Block
nope. some companys have the compression fitting ones. i have a RF fused one i got at best buy for $35 and it is awsome. but yeah you could make ur own. even on a piece of mdf with bolts and on the underside a piece of steel connecting the bolts.
get yourself a piece of nice 1"x4" brass bar (or something like that) and get a nice hexhead bolt. drill out two holes in the ends for the ring termanls so the screws fit, and two in the center. go buy an ANL fuse and cut thru the center of the bar between the two holes you drilled with a bansaw\hacksaw or whatever (sand\polish accordingly), and screw the ANL screw down to the center holes with your bolts. drill two more holes in between the ring terminal bolt and fuse holder bolt and tap once again. get a piece of plexi or wood or something and attach it via some flathead bolts using a counter sunk drillbit in the material. cover with some tape\glue so its not conductive on the bottom.
finish with some sort of cover if you can. it would look good but be practical too. you could also make it go from one bolt input to x number of bolt outputs. depending on how much metal you can aquire //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
easy day. a drillpress would help lol.
Does any company make a distribution block that distributed 1 ring terminal to two ring terminals. It can be a hunk of metal or fused, but I prefer ring terminal connections.
OR this...
http://www.cardomain.com/item/STISBTRN
that is not a distrobution block my little friend.
that is a ring terminal battery adaptor.
You are correct ..... //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Forgot the title of thread, and got mixed up with the 1 ring terminal to 2 ring terminals...
I get what's he's looking for now.
Flipx99
Violator of Terms
Flipx99
Building 100
djman37
