Southeast Region Richmond, VA - 08/26/2012 Likuid Glass Kustomz & Team Deadly Hertz Bass Off
AR,AL,GA,FL,KY,LA,MS,NC,SC,TN,VA
i have sd cards galore but cant get rid of lmao.... ill bring some things. and some audiotechnix wire for the new box. if we get to put it in and seal it if you dont think we can after the show i wont bring it
You should bring some 1/0 scrap and ring terminals for my batts
Looks like I'll be getting my *** handed to me in class 3 again but at least now I'm going in with a little more then 1000rms.
well ill be in 2 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
have none or i would
I prob won't do too good either. Classes are too broad
its the same as last time
They should do 0-1000 and 1000-up. How you going to have someone doing 501@4 in the same class as someone doing 2000@4?
I heard the meter is going to be in the kick and classes are set by cone area. That's what Nick Garcia posted a few days ago. I guess he is in charge of it somehow.
In that case I may have a chance!
You might be up against more power. Don't really know the details. I gain a db in the kick. Some gain more
guys forget what derek said. i talked to brandon and it IS NOT going to be this way. they wanted to try it but its wasnt in time
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
588
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
984
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Nice, much better looking version Ford than its American counterpart. Go down to the local stereo shop and tell them you want to the work yourself...
JayDubb757
JayDubb757
Hampton, VA
JayDubb757
SlugButter
    May 4, 2024
slater
    May 2, 2024
