Bossman150
So I have it narrowed down to two. The RF amp is used, the AB is brand new. Both about the same price. Both have more than enough power for my single 10w6v3. So far here is my pro/con list:
RF Pro - Higher end model from a brand I trust, value for the $ (since its used), slightly more RMS power @2ohm vs the AB (not really an issue since both are above the subs RMS rating), LOVE the look.
AB Pro - Brand new, flexibility if I add a 2nd sub in the future (does much more power @1ohm than the RF), warranty, would be purchasing from authorized dealer, like the look, fuses on board.
RF Con - Used (risk in purchase), no warranty or dealer support, needs an external fuse (nitpicking here).
AB Con - Unknown brand to me (although much less on an issue with research and poster support of the brand here)
After writing it down cons are pretty thin on the AB. Can I assume that the RF is a higher quality amp overall? Costs about double new, but that does not always mean everything.
Any other thoughts on these two amps or pros/cons I can add to the list? Told you guys I am OCD...
