1) Rockford fosgate punch500x
Rockford Fosgate Punch 500X 62.5W x 4 Car Amplifier at Crutchfield.com
2) Power1001bd
Rockford Fosgate Power 1001bd 500W x 1 Mono Subwoofer Amplifier at Crutchfield.com
1) Punch 500x 5/10 cosmetic. 5/10 mechanical
its a bit dinged up, and the right channels i believe have a static noise to them the left seemed to be fine. remote wire soldered on
62.5 watts RMS x 4 at 4 ohms
125 watts RMS x 4 at 2 ohms
250 watts RMS x 2 at 4 ohms in bridged mode
requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
2-, 3-, or 4-channel output
Tri-way capable (Tri-Way crossover required)
front and rear switchable high-pass (120 Hz, 12 dB/octave) and low-pass (80 Hz, 12 dB/octave) crossovers
MOSFET power supply and output devices
Maximum Efficiency Heat Sink Application (MEHSA) mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
*****•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
speaker- and preamp-level inputs
dimensions: 13-7/16"W (9-15/16" without endcaps) x 2-7/16"H x 9-7/8"D
2) power 1001bd 5/10 cosmetic 10/10 mechanical works just as it should.
only problem with it is that it is a direct lead amp lol, the inside piece of the terminals broke so i improvised and made direct leads, also remote wire is soldered on.
500 watts RMS x 1 at 4 ohms
1000 watts RMS x 1 at 2 ohms
Class bd technology
requires 4-gauge power and ground leads and a 100-amp fuse and fuse holder — wiring and hardware not included with amplifier
selectable 50-250 Hz variable low-pass crossover, 24 dB/octave
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise
preamp outputs for easy connection to a second amplifier
wired remote control of Punch Bass (0-18 dB centered at 45 Hz) — gives you fingertip control of your bass impact
bd Sync — allows you to bridge together two separate Rockford Fosgate Class bd amps (with an optional cable) to power one woofer
subsonic filter removes frequencies below 20 Hz for increased efficiency
13-1/8"W x 2-3/8"H x 9-7/8"D
1) $65 shipped and insured
2) $120 Shipped and insured
included in price as well as pp fees,
This is what broke on the 1001bd so i soldered wire directly into there
2) Power1001bd
Class bd technology
