Sold RF Power: 10001BD
Description Value
CEA-2006 Compliant
Number of Channels 1
Rated Power
continuous power 500W x 1 @ 4-Ohms
750W x 1 @ 2-Ohms
1000W x 1 @ 1-Ohm
Total Power
total sum of 'rated power' 1000 Watts
Bridgeable Yes (bd-sync2 cable required)
MasterSync
PowerSync
Crossover Controls Low-Pass (LP): 32-250Hz 24db/octave Butterworth
Infrasonic filter: 27Hz 12db/octave
Tone Controls Bass: 0dB to +18dB @ 35-70Hz
Phase: 0/180 degrees
Signal Input Low level: 1 RCA pair
Signal Output Low level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 1/0 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Fan cooled
Remote Controls ParaPunch Bass EQ (included with cable)
Visual Indicators Power On
Thermal Status
Speaker Protection
Circuit Topology Class Class bd
Frequency Response 20Hz to 300Hz +/- 0.5 dB
Shipping Weight 20.8 Lbs.
(9.4 Kg.)
Dimensions (HxWxL) 2.6 x 12.8 x 18 (in)
6.6 x 32.5 x 45.7 (cm)
brady_f
brady_f
Waco, Tx
JohnnyBASS
