RF P325.1 @ 1ohm or 2 with a P3SD210
barfy
23
SF, CA
Looks like that sub is a dual 2 ohm which means you can only hook it up as a one or four ohm load, and the p325.1 is only 2 ohm stable. Meaning you can only hook that sub up as four ohms.
you could get the p3sd410 and wire that as two ohms.
Thanks for the Help.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thats what I will do, I ordered the 2ohm and it didnt ship yet, I'll change the order.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks again..
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
Shipped from Amazon so its legit. Used it once before for something else and no issues.
  • Locked
GM-D9701. Used it to power a sound quality sub (Adire Brahma 15”). Was adult owned and carefully used (had a Mini DSP connected to it with a...
barfy
barfy
SF, CA
JeremiahCoffel
audiobaun
    May 19, 2024
    May 19, 2024
