Thedeadly1
I need help building this box. Because i dont understand
Use 3/4" material to build your box
Make your box with the following internal dimensions: W=32" H=13"
D=12.5"
Fire the subs and port to the rear. You will have a slot port; use
either end of the box end panels for the outer port wall. Center your
subs in the area between the inner port wall and the opposite end of
the
box.
Your port will be 3." wide and 13" tall and 20" long (measured from the
outer face of the box)You will have to bend the port 90 degrees at a
point 3" from the inside face of the rear box panel and continue the
inner port wall for a distance of 10.5"
Your port opening area will be 40 sq" and be tuned to approx 37 Hz
Your box will be 2.5 cubes net after displacements
Have fun
dj
I dont understand it.. is it literally for sides and then on one side a port cut out? on the same side as the subs? I dont understand how it could be both tall wide and long it just doesn't make sense. Help a brother out
D=12.5"
the
box.
Have fun
dj
