Resonant Freq. of Dodge Ram - help.
avs20
Ok, got a radioshack meter(I know a TL would be better, but there isnt one close to here) and played tones from 45-65hz. I tried it at 2 diff volumes.
Results w/first volume(60):
45-46hz - 111
47-48hz - 112
49-50hz - 113
51hz - 114
52-53hz - 115
54hz - 116
55-56hz - 117
57-61hz - 118
62hz - 117
After this it started dropping, so I quit writing.
Results w/second volume(50):
45-47hz - 101
48-50hz - 102
51hz - 103
52hz - 104
53-54hz - 105
55hz - 106
56-57hz - 107
58-59hz - 108
60-61 - 109
62-63 - 107
What do you guys make of the difference between the two tests?
i am also interested in finding an inexpensive way to meter\test my cars freq's and things. anyone know?
i dont know of any shops round here eaither. but i could be wrong.
well then 60-61 is your resonant frequency I could be wrong so don't quote me
Not necessarily.....that could have just been where his box peaks. To come close to finding the resonant freq, you'd need to perform the same test with the box in an open area (like your yard). Record the same frequencies with the meter at the same volume levels. The frequency with the greatest difference in db level (between in vehicle and out of vehicle responses) is close to the res freq.
But as Jmac mentioned, there are things that will affect the res freq; like volume level, sub placement, etc etc
How does the box 'peak' if it is sealed?
All boxes have a peak frequency and a certain response curve.....sealed included. Sealed's frequency response isn't just a flat line.
Most ported boxes just have an exaggerated peak and/or peak to a higher SPL than sealed.
The resonant frequency of the vehicle changes with the amount of flex in your body panels. That could be one of the reasons the meter detected the peaks slightly differently. On the other hand, that radioshack meter could just not be accurate enough.
If you were building a box, i would tune around 48-53 and burp at around 58/59
Ok. So if the res. freq of every vehicle changes with box placement, volume, etc..how can you even find the res. freq? Does finding the 'peak' with a meter just give you an estimate of where to start from?
This box will have a port plug...just need to find out what to tune to for burps so I can get to building it..
the freq doesnt change drastically, but it does change. From your testing, and the results you got, i would say your peak is right around 59/60 hz. If you are currently using a sealed box, and burping at 60, then thats about where you wanna burp with your ported box. Build a box with changable ports, not just a plug. Make a few ports for a few diff tuning frequencies, and find out which tuning is loudest.
I'm not running a sealed box. Im just using it to find the res feq. I ran a ported box before tuned to 35hz. I'm going to be building a 20ft^3 box..tuned low with a port plug for daily, and tuned high for comps..
avs20
avs20
Frisco, TX
avs20
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
