Reliable Fiberglass Resin
Originally posted by FAM4LIFE Whats a good Fiberglass Resin and where can it be found? Need something good with a quick dry time.
Now why would you need that:D //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Originally posted by RangerMan Now why would you need that:D //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
I plead the 5th.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
So, Home Depot, Lowes, Wal Mart..........Anybobdy?
Yep any of those. Also autozone and advance sell it too. Drying time really depends on how hot you mix it. If all you plan on doing is cough sealing your box cough //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Then mix in a little more catalyst than is suggested . Stir it up real good. And dump it in and spread it around as quickly as possible. It doesn't take very long for the resin to harden normally. When you add more catalyst it takes even less time. Just don't add too much catalyst or your resin will shrink and crack as it's drying. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by ramos Yep any of those. Also autozone and advance sell it too. Drying time really depends on how hot you mix it. If all you plan on doing is cough sealing your box cough //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Then mix in a little more catalyst than is suggested . Stir it up real good. And dump it in and spread it around as quickly as possible. It doesn't take very long for the resin to harden normally. When you add more catalyst it takes even less time. Just don't add too much catalyst or your resin will shrink and crack as it's drying. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
How much is too much? I'm an impatient man //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If the resin starts smoking you have added too much //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Seriously I usually try not to go over 1 1/2 - 2 times what is suggested. Otherwise it gets really hot really quick. And almost instantly turns to jelly. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
FAM4LIFE
SHILOH BOY
FAM4LIFE
Hampton, VA/Waldorf, MD
audiontz
