Spooney
I've searched every different way I could word it and never came up with any concrete answers for my question so here it is. I'm currently playing around with box designs for an L5 15. Not the greatest sub I know but bear with me. I got it in a box that came in at under 3 cubic feet with a 40 hz tuning(gay). So clearly I need a new box. Depending on the orientation of the sub on the box I can make the box a couple different ways. If I face the sub and port towards the back of the car I can only get about 3.2 cubic feet and still have respectable port area and tuning. Now if I face the sub up towards the trunk lid with the port still firing back(or sideways or whatever would work best) I can get more port area,tuning that would be respectable, and gain almost a full cubic foot of enclosure volume(4.15 as opposed to 3.2 feet). I gain so much on the volume this way because I can make the box shorter and wider and still fit it into my trunk. If I go with everything facing back I am stuck at the 3.2 cubic feet because the height of the sub determines the height of the enclosure and makes it too tall to fit in the car if the box was larger in any other dimension. Now the real question is which of these setups will give me the most gain? Is there more to be gained from getting all the air moving in the same direction(sub and port back)? Or is it more worthwhile to go with the larger enclosure and gain a little port area even though the sub and port are no longer on the same plain? I've had plenty enclosures where the port faced the side of the car and the sub faced the rear of the car and thought they sounded fine but I am just iffy on the whole facing up setup even though its a much better enclosure for this sub. It just would seem like if facing up was worthwhile you'd see a lot more setups like that in trunk cars. Any input would be greatly appreciated.
