Reducer question help QUICK
what do you suggest?
should i run a nonfused 0 to 4 distribution block?
should i run a fused 0 to 4 distribution block?
should i trim the wire down and put it in?
ground also
as in if you were worried that going from 0 gauge to 4 gauge was going to affect anything...it's not going to. In the past I've cut strands off, and electrical taped the shit out of it, didn't liek the look, now I have a distro block from 0 gauge to 4 gauge, and same for the ground cause I have 2 amps, and have ground going to straight from battery in front.
mustbenu
mustbenu
new jersey
mustbenu
