splduck1978
My GF works at autozone and was thinking about getting me a new battery for my new set up. What would you suggest under the hood?
i emailed them ill let you guys know what they say.I would ask optima about a red top. http://www.optimabatteries.com they will probably suggest it be used with an isolator in an audio system.
With a large audio system you should use YellowTop batteries.
If you are wiring the batteries in parallel you should use batteries of the same type, both YellowTops. Whenever batteries are wired in series or parallel they should be the same size, type and age.
You can use a RedTop for starting and a YellowTop for your accessories if you use a battery isolater.
Thank you,
Daryl
Optima Customer Service
