Recommend box size for single Alpine SWR-1241D
  • 2
Tungsten
Hey folks...
I'm working on adding a subwoofer to my system and have decided on an Alpine SWR-1241D to be powered by an MTX 6500D amp. My goal is to have tight, accurate, deep bass with an emphasis on sound quality. SPL is a nice secondary benefit, of course... but it is not my primary goal. The car in question is a 1998 Ford Mustang GT.
My preliminary box design is a sealed "irregular rectangle" (wedge, shorter top, longer bottom) that will fit almost flush against the rear seat area from inside the trunk. I will most likely mount the box in such a way that about 2" of space exists between the actual back of the seat and the face of the box / subwoofer so that there's little chance of the sub ever bottoming out against the seats.
The airspace that I have been using for my box calculations thus far is 1.0 ft^3 -- taking into consideration the approximate 0.128 ft^3 displacement of the sub basket and motor assembly. Total volume, therefore, is 1.128 ft^3.
What do you all think; is this enough airspace or should I go for more or less?
Alpine's specs recommend a range of .7 - 1.0 ft^3 for the sub but when I ran the T/S parameters through BlauBox (yeah... I know) it showed that 1.0 would actually provide a flatter response curve.
I'm completely open to suggestions, so fire away. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Thanks for the reply, Jmac...
No, it will be just a single SWR-1241D sub wired 2-ohm mono. Alpine rates them at 300W RMS (150W per coil) and the MTX amp should be feeding it a little over 200W per coil at +12Vdc.
I intend to keep the gain on the 6500D set around 80% of maximum and rarely crank the volume on the HU past 75% of maximum so I figure this will be well within the 1241D's ability to handle and certainly below the 6500D's clipping threshold. Good clean power.
Granted, maxing out the 6500D would definitely be more than the sub can handle... and if I ever get to that point I will likely upgrade the sub to something a little more robust. But SPL isn't really a concern of mine at this moment. Just accurate bass.
Thoughts?
As a side note... I can go with two 1241D's and wire the coils in series on each and then parallel the two subs so that they each see around 125-150W per coil if that sounds like a better approach for safety's sake. I'm just concerned that two 12's will be a little more bass than I really want for the system.
Hmmm... MTX is really under-rating their amps these days, I guess. I'm not doubting you -- I'm just looking at a spec sheet from http://www.mtx.com that claims 500Wx1ch @ 2ohms and a peak output of 775Wx1ch @ 2ohms.
Are you thinking of the 8500D perhaps? That's my amp's bigger brother. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
BTW: I am all for getting more power than I expected out of the amp; it just changes things dramatically if it's the case. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Originally posted by Jmac Nope ... that's how much the 6500Ds do ... The 81000Ds put out outrageous power (1700-1800 RMS into 2 ohms) ...
MUAHAHAH... sweet. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Thanks for the info, man. It sounds like I may need to have a second set of plans drawn up for a dual sub box just in case. I can order another 1241D and do the series/parallel wiring scheme and keep it safe that way.
So anything upwards of 1.0 ft^3 per sub for a sealed enclosure, then?
Thanks again! I think I will revise the design for 1.25 ft^3 and then draw up another box using the same per chamber on a dual-sub setup just in case I decide to order another 1241D before actually beginning construction.
Can't wait to get this put together and see how it actually sounds in the car. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Okay... I designed a sub box that provides 1.242 ft^3 airspace per sub taking into consideration a 0.128 ft^3 speaker displacement.
I guess the 0.008 ft^3 difference between the actual volume and the ideal volume of 1.25 ft^3 per sub really isn't going to make that much of a difference in terms of Qtc. Besides, this is the closest I could get without really splitting hairs and making some really unusual board cut lengths. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Originally posted by Jmac Sounds good //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Let us know how it turns out //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Will do. Actually... I am looking at the idea of returning my 1241D and using two 1021D subs instead. I can wire them series/parallel and actually present a 2-ohm load to the amp while limiting the subs themselves to about 125-150W per coil, well within their rated limit.
You've been most helpful, Jmac! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by Jmac 1.25 ft^3 per sub gives a Qtc of .707 (Good SQ and SPL mix)
1.5 ft^3 per sub gives a Qtc of .67 (Less SPL, more low-end, more accurate response)
2 ft^3 per sub gives a Qtc of .625 (Even less SPL, even more low-end, even more accurate)
Jmac...
Do you have any figures (or can you calculate them or point me toward a program or formula that will) for box volume -to- Qtc comparison on the Alpine SWR-1021D sub?
I may end up going with two of them instead, as described in my previous post.
Thanks! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I started playing around with WinISD and a few others again and came up with a Vb of 0.416 cubic-feet for the Alpine SWR-1021D subwoofer to achieve a Qtc of .71
That sounds small. Is my math right? Thiele/Small parameters for this sub are as follows:
Alpine SWR-1021D
Coil Height (Hvc) : 36.7mm
Cone Area (Sd) : 320.47 sq. cm
D.C.Coil Resistance (Re) : 1.8 ohm + 1.8 ohm
Electrical Q (Qes) : 0.40
Equivalent Suspension Stiffness (Vas) : 29 liters(1.02cu.ft.)
Free Air Resonance (Fs) : 29Hz
Frequency Response : 28Hz - 1kHz
Gap Height (Hag) : 10mm
Impedance (Nominal) : 2 ohm + 2 ohm
Inductance (Le) : 2.67mH at 1kHz (0.88mH at 20kHz)
Linear Excursion (X linear) : 13.35mm
Maximum Excursion (X peak) : 26.7mm
Mechanical Excursion (Peak-to-Peak) : 55mm
Mechanical Q (Qms) : 8.93
Sensitivity : 85 dB/W/M
Total Loudspeaker Q (Qts) : 0.38
Originally posted by Jmac I would go with 0.8 ft^3 per chamber //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Is that before or after you consider the displacement of the speaker itself?
Originally posted by Jmac After speaker and brace displacement //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Speaker displacement is 0.094 ft^3 per sub ...
Excellent. I was able to modify one of my blueprints so that it yields .92 ft^3 total internal volume without the subwoofer displacement / .84 ft^3 with the subwoofer. Very close to your recommendations.
While we're on the subject, what software are you using (if any) to do your calculations?
If I use two of the Alpine SWR-1021D subs (2ohm + 2ohm coils):
  • Each subwoofer has it's voice coils wired in series to present a 4ohm load (per sub).
  • The two subs are then wired in parallel to the MTX 6500D amp to present a 2ohm load.
  • The amp yields 900W (RMS) at 2ohms, so this means...
Each sub "feels" 450W and each coil gets 225W or pretty close to it. Right?
Originally posted by Jmac Yup //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Although I would watch the gains and not use bass boost .... The 10"/12" Type-R motor is only rated to handle 300 RMS or 150 RMS per coil (Although mine did find with 365 RMS) ...
Yeah, I will keep the gains on the amp turned to about 75% - 80% of maximum. I like to have a WIIIIIIDE safety margin on stuff like that. And I think the bass boost circuitry adds unnatural artifacts to the sound, so I'll leave it off anyway. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
BTW, I redesigned the box from scratch and came up with .82 ft^3 per subwoofer (considering displacement of basket and motor structure) which is within .02 ft^3 of the ideal target range you came up with. Hopefully it'll sound tight and clean! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
My 2 12's in .9 each never whimperd with 1200 watts on them ! And well I pushed em hard for a good while !
One thing I’ve noticed about reading reviews is those who cannot spell offer very colorful and misspelled adjectives to describe products. Take...
I’ve never owned them but have heard a lot of crossfire products and like them a lot.
22
3K
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
154
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
452
Tungsten
Tungsten
South-Eastern USA
Tungsten
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
