Rebuild is on it's way.
October 14th 2008: Well guy's I went and pulled the subs , sub amp , Box all out today. I will miss having Bass //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif but i figured wanted to get it done before the winter weather/fall weather got here. Here are some pics 4 u guys:).
The sub's are out & the box is almost out.
The enclosure is out along with the sub's
The Sub amp is also out but i just never took a pic of that .
Well guy's i got my DLS A3 sold. Now im thinkn i might wanna Run one AQ HDC3 18". Do this for an enclosure
run around 4 cubic feet after displacement of everything for just one and give it at least 2000 watts rms.
im thinkn id be mid 140's maybe can do a 150 if im lucky.
Well guy's my AQ HDC3 18" is on it's way:D (much thanks to jdk32sho). Now guy's i need plan's for box idea's what should i do cause i found out 4cubes would be choking that sub.
Put it in 6 cube @ 38hz, use 3 or 4 6" aeros //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Sweet man sounds 4 for sure:D.
October 16th 2008: I got my ring terminals in from 5.0:D. There pretty nice terminal's also.
there TRUE 1/0awg terminals;).
Im also using 1/0awg terminal's i got from carquest which are also TRUE 1/0awg terminals:D.
Well guy's after much email's back and forth with Dj from AQ (also before i go further DJ is a great guy and responsds very quick to email AQ has great customer service). But with that said i will be doing an enclosure of 6cubes 38hz with 2 6" aero's (external) 13"long.
audiobahnuser18
audiobahnuser18
Mi
audiobahnuser18
