re8s
so when i set my amp do i want the level and bass boost to equal the volts given in the tutorial or do i want the level to equal that and just play with the boost? Would 500 watts between the 2 be good, if not more or less?
According to the box, they should be ok. I just bought (4), and I got a good laugh when I read the side of the box. . .
do the 1.2 tuned to 35hz design. With the power at 1ohm you won't want or need the larger box.
I ran a bunch of em in .5 cubes each tuned to 33hz and they sounded **** good. I gave em each about 250 watts and they took it fine. Run em at 1 ohm, you won't need any bass boost with the power yo uwill have on em.
Just don't go gonzo on them right away. Hook em up and slowly go up with the volume. They will bottom out when they have too much power, you will instantly recognize the sound. If/when they do you will know your limits on em //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
jmoneypierce21
jmoneypierce21
Centralia, Wa
cman0655555
