Re xxx 10"
lmao ha ha ha sorry president of re,sorry i had to. the owner of FI sold re audio and it went down hill after that.
sure fi could build you a nice recone and so could i totally up to you //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
No prob, ill lol with you. Im not on his ******* or anything, just thought that it was a plus that he had actually had direct experience with the woofers. I have preference with who i choose to do the recone, as long as its as close to original spec as possible or even better.
Corey would make it better than original. Not that i'm cockriding or anything, but it is the truth.
1) Designers at some corporations don't know the best ways to build when they are designing.
2) Years of use have shown certain weak points in the design that weren't seen during testing and can be improved upon.
3) Manufacturers cut costs by using slightly cheaper alternatives that modern builders wouldn't use.
4) Better materials have come along that modern builders could implement into the design.
5) Modern builders will use top notch assembly glues and materials that eliminate failure at their points in the design.
There are other ways to improve factory equipment. Corey can change the power handling of it to take more power or less, depending on what you want. He can use higher excursion surrounds if you want or whatever. Tons of possibilities.
dont remember them with a 4 spoke?
they came in both I believe. I had theses but now I just have one with fresh recone. D1 These had quad 1ohm coils each.
#1Tunna
Papio Slayer
#1Tunna
Wailua, Kaua'i (HI)
SPLaudio
