Brand new 2004 Kicker S12l7....Never been used Still in box 180$ shipped
750W rms
1500w peak
87.4 Sensitivity
Resonant engingering Sx 15" duel 2 ohms... used but not abused at all. Works flawless 250 Shipped
Dual composite 2 piece cone
Rubatek foam surround
Cast aluminium basket
Tork-Tite terminal
4 layer copper voice coil
FEA optimized TG technology motor structure
Triple stack magnets
Progressive spider
Wrap around rubber gasket
1000wrms power handling
DIrected Audio 1100d MONO AMP 230$ shipped
http://www.evosoft.dk/hDirected_audio/classdmono.htm
Rms Power
1100 watts @ 1 ohm
800 x 1 @ 2 ohms
425 x 1 @ 4 ohms
*High speed MOSFET switching power supply
*High current complementary MOSFET outputs stable into 1 ohm loads
*Thermal, DC offset, over/under voltage, reverse polarity and short circuit protection with status LED
*Master/slave RCA jack functions support two amps bridged to one load, or multiple amps driving separate loads with synced gain
Top-mounted controls easily accessed for system tuning
Continuously variable 18 dB/octave low-pass crossover ¤
Switchable 30 Hz, 24 dB/octave subsonic filter
Switchable 8 dB bass EQ function
Switchable phase invert function
750W rms
1500w peak
87.4 Sensitivity
Tork-Tite terminal
Progressive spider
Rms Power
1100 watts @ 1 ohm
800 x 1 @ 2 ohms
425 x 1 @ 4 ohms
