I have one D4 ohm 15" sub. I am asking 100 OBO, Please Be reasonable.
Specs:Engineered with new magnet covers that aid in cooling the voice coils while protecting the magnet
Flat wound voice coils
Kraft Pulp Cone
Rubatek Foam Surround
Pressed Steel Basket
4-layer Copper Voice Coil• FEA Optimized Motor Structure
Double Stack Magnets
Linear Spiders
Foam Gasket
Mounting Depth - 6.75"
Mounting Hole Diameter - 13.75"
Overall Diameter - 15.5"
Bolt Hole Circle - 14.75"
Motor Width - 6.25"
Motor Depth - 2.5"
Basket Depth - 4.25"
Displacement - 0.16 cu. ft.
Weight - 17.5 lbs
QES: 0.45
QMS: 4.87
QTS: .41
Free air Resonance - FS - 23 HZ
VAS: 203 Liters
XMAX: 18 MM
SPL @ 1W / 1M: 87.6 dB SPL
Effective piston area: Sd: 810 cm ^2
Dc Resistance: RE: 1.8 ohm
Nominal Impedance: Dual 4 Ohm
300w RMS Rated
600 watts max
Force Factor, BI: 14.35
Kraft Pulp Cone
Linear Spiders
Foam Gasket
Motor Width - 6.25"
Motor Depth - 2.5"
Weight - 17.5 lbs
QES: 0.45
QMS: 4.87
QTS: .41
VAS: 203 Liters
XMAX: 18 MM
300w RMS Rated
600 watts max
