Before/after sub blah blah blah. You need 2 net cubes of volume. If you built your enclosure as a single sealed chamber (no sub, port, or bracing), the inside volume would be your gross volume. Here we go:
Net volume + port displacement + sub displacement + bracing displacement = gross volume.
I did a box design for someone last night. His gross volume was about 1.77 cubes, his port displacement was 0.25 cube, sub displacement was 0.1 cube, and bracing was 0.15 cube. This left him with 1.25 cubes, which coincided magically with his net volume of 1.25 cubes.
You want about 24-32 inches of port area for that sub... depending on how much power you plan on it seeing.
T
