Sold RE MT15 quad 1.4
MrFlamboyant
now is your chance to own it....i have here a pre-production model MT15. tried and tested by myself, one of the baddest SPL machines out there, with MAJOR magnetic energy! (1 more magnet than XXX)
all you need is to strap about 8 of the most powerful amps you can afford to its quad 1.4ohm coils.... does your ride have the nuts to contain this monster??
barely used and in pristine condition electrically/mechanically, not even completely broken in yet. it was briefly powered by a Planet Audio 2250D for about 2 weeks to see what it can do. and take my word, it CAN DO!
check out some pics i took today
http://images.cardomain.com/member_images/12/web/192000-192999/192579_75_full.jpg
http://images.cardomain.com/member_images/12/web/192000-192999/192579_76_full.jpg
http://images.cardomain.com/member_images/12/web/192000-192999/192579_78_full.jpg
$425+ shipping and its all yours. you will not be disappointed with what you get. anyone who knows me will vouch for my integrity, and i have many references....
post any questions here for fastest response...
thanks for looking
sorry no break for local pickup... while its design is pure SPL, there were a lot of listeners that wouldnt mind using the sub daily, in a low-tuned enclosure... i used a box that was tuned @ 31Hz, with awesome response down to 25Hz at impressive pressure levels. peak output was in the 40Hz range, and even with 2,000 watts maintained great posture and control. ofcourse it was begging for more clean power.....
the MT is atleast comparable to a DD9500 in SQ..... if you want a 70/30 SPL/SQ setup or if you want to do some serious competition then this is your sub... and yea, planet amps rock...
check out these little tiny buggers that pump out 1Kw continuous! are strapable, and chuck full of good stuff....
The only reason David says not to use it for daily is because the gap is so tight in it, that a wrong movement could scrape the coil and ruin it, he runs his daily,but if a coil is screwed up he can fix it in 5 minutes for free, and we have to pay 100$ish and wait a week or two.Gap tight=bad for music.
the gap is no tighter than an IDmax or MTX 9500.... they would suffer the same consequences if what you say is true.... but i've owned them all, and listened quite extensively, no signs of scraping or failure..... im confident it will opperate normally....
thanks for the concern...
Its not INCREDIBLY tight, but I said so because that is the main reason David suggests not to use it for daily, so no coil gets scraped. It was just a lil blurp thats all, he has run his daily fine and nothing has gone wrong, I just said be careful of the daily because David had warned me.
MrFlamboyant
MrFlamboyant
Seattle, Wa
MrFlamboyant
