I am moving on to some more bigger and better things. So I am selling quite a few of my audio equipment that I have.
I have a Dynabel 7501 Amp that I purchased from TeamSolo a while back..
The Specs:
2500x1 1ohm
1400x1 2ohm
750x1 4ohm
300 + Shipping + PP Fees
The case is a bit dusty has a few scratches on it outside of that it is in perfect working order. I ran it with a Deka batt and a batcap 2k and it never got more then warm..
Next I have a RE HC that was custom built by Scott @ FI... I don't want to let go of this sub as it sounds great and pounds like heck.. The backplate was plugged to aid in cooling and Scott used a different set of spiders on it then what it came with from factory years ago. The sub was built to handle 2k watts of power and it ran fine on my Dynabel amp.. It also has woven tensil leads as well. It's a 15" if it was a 12" I would keep it. The specs below was taken after it was rebuilt by Scott after break in.
Specs:
RE 2.8 Ohms in series
Fs 34.4Hz
Qms 5.33
Qes .52
Qts .48
Mms 220 g
Cms 9.7 10^-5m/N
Vas 89 l
Sd 810 cm^2
Bl 16 N/A
SPL 90.3 1W/1m
Price - 225 + shipping + PP fees
The Specs:
2500x1 1ohm
1400x1 2ohm
750x1 4ohm
Specs:
Fs 34.4Hz
Qms 5.33
Qes .52
Qts .48
Mms 220 g
Cms 9.7 10^-5m/N
Vas 89 l
Sd 810 cm^2
Bl 16 N/A
SPL 90.3 1W/1m
