re-cone question
  • 6
here are the specs to it. its discontinued but is there a recone that will fit it??
Cloth laminated paper cone with MD6 coating
• Dual 1 ohm voice coil
• Die cast aluminum basket
• Aluminum/chrome dust cap for extra rigidity under extreme conditions
• Black wrinkle finish with Diamond cut
• Chrome finish front & back plate
• Large roll treated foam surround
• One piece, 360º rubber gasket
• Dual conex spider
• Woven tinsel lead through spider
• Chrome binding post terminals
• 2800 watts power handling
• 1400 watts RMS
• 340 oz. magnet
• 4” BASV/Kapton hybrid 18 awg voice coil
• FS 29.1(Hz)
• Vas 1.6 cu.ft.
• Qes: 0.52 • Qms: 4.06 • Qts: 0.31
• Xmax: 0.59”
• SPL 92 dB
• Sealed box: N/A
• Ported box: 3.4 cu. ft.
• Tuning: 40 Hz
• Port size: 4” (dia) x 10” (length)
• # of ports: 2
here is a pic...
looks alot like the magnet and basket of my aw1505s. if you find a recone that will work let me know b/c im looking to recone 2 extras i have
you may be able to replace it for what a recone kit cost. the recone kit will probably cost some around $100.00. + the cost of ca glue. ca aint cheep.
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
748
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
299
664
IbSlamn
IbSlamn
Alabama
DonH
    May 31, 2024
    May 24, 2024
