Sold RE Audio MX 15d2 sub NEW!!
1 Hugh Jass
Brand new, never used RE Audio MX15d2 sub. It has been mounted on a display, but has never had power to it. It is boxed up in the original box/crate from RE. This thing weighs 60 lbs, so shipping may be a little steep, but I will work with you to try and keep it affordable.
I do take PayPal, but would prefer USPS money order.
$300.00 plus shipping.
• Dual Composite 2-piece Cone
• Rubber Surround
• Integrated Gasket
• Cast Aluminum Basket
• Tork-Tite Terminal
• 4" 4-layer Aluminum Flat Wire
Voice Coil
• FEA Optimized Motor Structure
• Powerful Neo Magnet
• Dual Progressive Spiders
• Integrated Tinsel Lead
Specs:
Electrical Q Value -Qes: 0.561
Mechanical Q Value -Qms: 3.098
Total Speaker Q Value -Qts: 0.475
Free Air Resonance -Fs: 20.775 Hz
Equivalent Compliance -Vas: 166.25 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency -SPL 1W/1m: 86.113 dB SPL
Effective Piston Area -Sd: 810 cm^2
DC Resistance -Re: 1.4 ohm
Nominal Impedance -Znom: Dual 1/2 ohm
Thermal Power Handling -Pe: 1500 W
Force Factor -Bl: 14.56
Mounting Depth - 11"
Mounting Hole Diameter - 14.5"
Overall Diameter - 16"
Bolt Hole Circle - 15.25"
Motor Width - 8.5"
Motor Depth - 2.5"
Basket Depth - 8.5"
Displacement - 0.22 cu. ft.
Weight - 36 lbs
1 Hugh Jass
1 Hugh Jass
Amarillo, Texas
1 Hugh Jass
vegang
vegang
