Rd D9
9515ROB
TEAM DTF
1. Product:
RD d9
2. Specs:
RMS power, 2 ohm linkable/dual mono
RMS power, .75 ohms mono 5400
RMS power, 1 ohm mono 3600
RMS power, 2 ohm mono 1800
RMS power, 4 ohms mono 900
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 500 amps
Input Sensitivity 200mV to 6V (+/- 5%)
3. Description/Condition:
8/10 cosmetically 10/10 mechanically. The amp was repaired once for a problem with a loose rca input or something. Works great tho now havent had a single problem with it
4. Price: :
800 shipped
5. Pictures:
9515ROB
TEAM DTF
9515ROB
Sherman IL
9515ROB
