RCA's
Ruthless Pastor
Is it worth it to spend the extra money on the better KnuKonceptz RCA's?
The least expensive:
http://www.knukonceptz.com/productDetail.cfm?prodID=KLS-2M#
Next:
http://www.knukonceptz.com/productMaster.cfm?category=Klarity%20RCA%20Kables#
Most expensive I would get:
http://www.knukonceptz.com/productMaster.cfm?category=Karma%20RCA%20Kables
The Karma cable are twisted pair, does that make a big difference. Also, I don't see much difference between the Klassic and Klarity. Anyone have experience with these?
My answer yes... What is all in your system? If you don't have high quality gear then don't upgrade IF YOU DO then DO upgrade. Most people on here will totally disagree with me but I notice a difference inbetween regular cables and good ones. Also, check out Straight Wire and Nordost those are the ones that I use.
The thing I look for in cables is;
1. Robust contruction so they don't break, ie thicker jacket, thicker wire size.
2. High % shield coverage.
3. Low capacitance per foot. This is the all importance specification.
For short runs, lets say less than 50 feet of signal travel, even a cheap cable
has low capacitance. If you have large runs, then you really do need to look
at cable capacitance as the cable forms a low pass filter between source
and destination gear {impedances of those equipment + cable capacitance,
determine the cutoff frequency).
Ruthless Pastor
Ruthless Pastor
Central NY
thylantyr
