WOT
Banned
Having som trouble getting much bass out of my setup (4 15's on 2 1ohm amps) Since I have 3 rca outputs on my deck i decided to run one to my speaker amp, and use the other 2 outputs off my deck to run each of the subs. So one amp has the actual sub output and the other is using one of the other outputs (forget which, but I believe its using the mid/high)
Would this affect anyting?
I was debating just splitting the rcas for the subwoofer output if thats what was needed.....
OR
My amps have an input and output rca. Can I run the proper rca from my hu's sub output to one amps INPUT, then another set of rcas from that amps OUTPUT to my other amps INPUT? Does that work like that?
dont know if its makes a difference....
OR
