RCA wire question ?
It's actually a ground drain wire. On some amps there's a small ground terminal (separate from the power ground terminal) and you're supposed to connect one end of the small wire to the amp, and the other to the chassis of the head unit to help avoid ground loops. However, most new amps don't have the terminal, and I've never had any problems from not using the wire. It's also commonly used as a remote turn-on wire, and it will work fine for that too.
You can buy female-female RCA couplers just about anywhere, but you're probably better off just getting a longer RCA cable.
I was waiting in some one to say that.
being that the wire is in the center - seperate from the rca cables themselves I'm going with remote turn on. In my (I'll admit it - limited) experience with different rca's it seems the type that use drain wires are much less common than the ones that include a remote wire. If the wire's exposed at both ends it's a remote wire. Drain wire is only exposed at one end and is actually part of the signal wire (oh - and it's useless).
00_Z
www.got-traction.com
00_Z
Dallas,Tx
n2audio
vegang
vegang
