RCA preout question?
zeruin
Hey guys.. How exactly do RCA preouts work with a headunit that only has 2 sets of preouts?? I'm looking to install 2 amps, a 4ch for the front/rear speakers and mono for a pair of subs. I'm looking into the Clarion CX609, it has preouts labeled, Front, Rear/SW.
Question: If I hook up the 4ch amp to the Front preouts and the mono sub amp to the rear, will I still be able to fade the rear speakers from the headunit, or will that control/fade the subwoofers? What are my options for wiring everything up to the source? Would I be better looking for a 6ch headunit?
btw.. I'm really set on the Clarion CX609, simply for the design and display.. it looks like a stock double din source, and allows me to adjust the color of the display/buttons.. I drive a Ford, so all my buttons in the truck are mostly green.
look here for an idea what I'm looking for >>> http://www.sonicelectronix.com/item_17681_Clarion+CX609.html
I'm willing to consider other headunits just so long as they can be able to have green lights.. lol //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif but I don't want or need a DVD/GPS capable headunit.
To answer, yes you COULD fade but it would have to be done at the amp (gains). Because you only have 4 channels, you would most likey hook up 1& 2 to the front and 3 & 4 to the sub (set as Non Fading). THEN take 1 & 2 and Y split them at the amp to get full use of your four channel. If you want to fade at the Deck you'll have to find a better option. (OR if you'll only be fading 1 direction you could use that signal to Y split to the mono amp. OR if your mono amp has preout, send that preout back to the four channel to which ever direction you won't be fading)
zeruin
zeruin
Texas
m2002brian
