rca cables
titanle
Does an average rca compared to a high end rca differ much in SQ? The ones I have say "IConnect" on them, they are in a clear jacket and the actual cable is blue and white. I cant find them online anywhere and am curious whether they are good, average, or crap.
If you havent heard of them and cant find info on them, chances are they arent too great.
In a system that is setup really good, you will most definitely hear the difference in signal cables.
the ONLY difference in RCA cables is build quality and noise rejection. Period.
Let the tard debate begin.
Build quality is a definite.
One of the biggest failures I have seen with customers coming into the shop with Alternator Whine, static, intermittent signal, and no sound was because of broken or loose connections on the RCAs from installs done at home with cheap Flea Market RCAs. And quality Alfine amps.
Build quality is a definite.One of the biggest failures I have seen with customers coming into the shop with Alternator Whine, static, intermittent signal, and no sound was because of broken or loose connections on the RCAs from installs done at home with cheap Flea Market RCAs. And quality Alfine amps.
That kinda ties into build quality of the RCA's right?
titanle
titanle
BC, Canada
blazeplacid
