RCA Cable Help
PILOT 04
I am currently looking to purchase some RCA interconnects for my system. As everybody I am on a budget so $ is kind of an issue. I am looking at the two following interconnects and wanted to get everybodies opinions. Thanks....
Streetwires ZeroNoise® 2.0
ZeroNoise® Interconnects are the most sophisticated mobile audio cables in the world. Period. ZN Interconnects feature twisted-pair construction for all of the music with none of the noise. The input end features a ferrite inductor core to further reduce noise-causing radio frequency interference. The patented ZeroNoise® RCA connectors feature the compact Sure Grip design for easy installation in tight places. The connectors are 24-karat Gold Plated for maximum signal transfer and corrosion protection, with split-tip RCA center pins for the most secure contact.
· High quality oxygen-free copper for enhanced signal transfer
· Polyethylene dielectric for superior imaging
· Highly flexible Ultra-Flex purple outer jacketing
Stinger Hyper Series
HYPER SERIES: Exciting new RCA ends add to the already legendary Hyper cable! The Hyper still features a directional twisted-pair configuration within a 5.5mm single outer jacket. Integrated twisted drain wire and outer foil combine to provide excellent noise cancellation. The new molded RCA ends feature 24K gold plated contacts with split-tip design
Pretty much the best way to go about buying interconnects IMO is to ignore all the marketing and salespeople, forget about anything with "Monster Cable" on it and get a basic shielded interconnect that you like the looks of and can stomach the cost of. I presonally use the Stinger Bullet series because they fit the look of my install and for about $20 a cable the price was very good. You don't need foil wrapping or some crazy shielding. Basic shieding is more than adequate in the car.
The Streetwires have better build quality ....
PILOT 04
PILOT 04
OHIO
PILOT 04
BP1Fanatic
BP1Fanatic
