Rare Phoenix Gold Roadster 66 5 channel class a/b class d SQ amplifier!
Shinju
Up for sale is a limited edition phoenix gold roadster 66, This is a hybid class a/b class d 5 channel amplifier using 2 seperate boards under one heatsink. Only a 1000 of these exist, and I have 2 of them and I only have room for 1!
This amplifier is a monster in size and power, Amp is in great condition with a few light scratches. This was a wall display at a local stereo shop that is no longer in business so there is no paper work or flight case or #/1000 badge.
This beast works 100%
The memphis and Orion amps are just in the photo for size reference.
Specs:
PERFORMANCE DATA
Output power @ 1%THD, 1kHz/100Hz, 14.4 volts
Fullrange channels, 4 ohms 81 watts x 4
Fullrange channels, 2 ohms 136 watts x 4
Subwoofer channel, 4 ohms 407 watts x 1
Subwoofer channel, 2 ohms 656 watts x 1
Output power @ 1%THD, 1kHz, 12.5 volts
Fullrange channels, 4 ohms 60 watts x 4
Fullrange channels, 2 ohms 97 watts x 4
Subwoofer channel, 4 ohms 309 watts x 1
Subwoofer channel, 2 ohms 498 watts x 1
Distortion at rated power, fullrange channels 1kHz, 14.4 volts 0.07%
Input sensitivity 199mV - 9.3V
Frequency response (+ 3dB)
S/N Ratio (A weighted, full 4-ohm power, min. gain) 102dBA
Stereo Separation (Crosstalk) -57dB @ 5kHz
Output Impedance @ 100Hz, 4 ohms 0.03 ohms
Idle current 2.6A
Maximum current consumption @ 2 ohms, unclipped 123 amps
Efficiency at 1/3 power lowest impedance 27.2%
Efficiency at full power, 1%THD, lowest impedance 58.5%
Crossover, Fullrange Channels
Highpass 40Hz - 400Hz
Lowpass 40Hz - 400Hz
Slope -18dB/octave
Crossover, Subwoofer Channel
Lowpass 30Hz - 300Hz
Slope -18dB/octave
Subsonic filter -18dB @ 5 - 55Hz
Dimensions 31.75"L x 11.5"W x 3.25"H
Firm at 400.00 + shipping ConUS no trade offers.
That's a helluva deal on that amp, Jeremy. I'd raise the price if I were you haha //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif GLWS!
He is about right on the price. You would think a LE PG amp would go for more, but without a case it kills the value. PG collectors are perfectionists. They want there gear complete and perfects, but they shell out dough to get those fine examples.
Well I said that because the last time I saw one at an audio shop, they wanted $1500 for it haha
If it had the id out of 1000 badge it would be at a higher price point, so I figure at 400.00 + shipping this should move quick. You will be hard pressed to find a 5 channel of this caliber at this price point.
It grows on you, when I first saw one I hated it but now after owning 2 of them and getting to see it in person I think it is probably one of the better looking limited edition amplifiers made.
Sometimes simple is better.
Shinju
Shinju
Seattle
Shinju
