Sold RARE BNIB Eclipse CD8454
azngotskills
Well I really really dont want to do this, but i got into a wreck and need to pay for the deductible //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I was planning to keep it as a collector's item or possibly use it because i LOVE this HU (transport, DSP, functions, and look). I know the Eclipse CD8454 isnt a rare HU per se, but finding one BRAND NEW IN BOX is IMO //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I havent even unwrapped the factory packaging on the HU, wires, manual, etc
It can do 3-way active xovers, T/A, EQ, but also simple to go passive and sound great. Standard and Pro Modes. Will play MP3 via CDs, Aux-in, and fantastic transport. I have bought and sold 3 of these, i just seem to always go back to it for some reason. I honestly put its sound quality and functions in the same category as the highly acclaimed CD8053 and CD8443 IMO (yes i have hear them). Perfect for a collector, car audio beginner, or seasoned veteran that knows the good stuff //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Looking for $325 shipped OBO....PRICE DROPPED $295 shipped
Here are some specs that I copied and pasted:
* The flagship unit in the new CD Receivers, the CD8454 sets a new standard in audio-dedicated music reproduction for the mobile environment. Whether the program source is CD, CD-R/CD-RW, MP3, radio broadcasts or even WMA files on a Memory Stick, sound quality is always exceptional. Music takes on the effortless quality that is the hallmark of the best audio components.
* High Preamp Output Voltage The CD8454 circuits deliver a very high preamp output of 8 volts to help lower system noise and increase system dynamics since the power amplification stage can be driven optimally. The output signal’s low impedance of 55 ohms is also electrically ideal for audio signal transfer.
* Full-dot Vacuum Fluorescent (VF) Display This display makes best use of the space available with alphanumeric characters that retain high contrast in all light conditions. Brightness levels can be set to suit user preferences for day and night driving conditions and illumination can be switched from green to red. A graphic assist function helps confirm parameter changes.
Specifications: NOB Remote Control CD Changer Control CD-R/RW WMA MP3 Digital Servo System (DSS) TUNER STARTUNER® V Station Name Input AUDIO Output voltage and impedance 8V 55 Ohm MOSFET Amplification All digital circuitry 24-bit DAC DSP with Time Alignment, Parametric EQ, Crossover Electronic Crossover Control Non Fader Pre-out Dual Pre-out Digital Input Digital Output (for E-com) AUX In MEMORY STICK ATRAC3 Decode/Encode E-iSERV Connection Memory Stick ESN GENERAL ECLIPSE Security Network Display VF (Full dot) Full Face Tilt Bright & Dimmer Control ECLIPSE COMMANDER ADVANCE ready E-LAN data link system Current Drain 3A Dimensions (W ×H × D) 7" × 2" × 6-1/8" (178 × 50 × 155mm) FM TUNER Frequency Range 87.75 ~ 107.9 MHz (200kHz step) Usable Sensitivity 13dBf 50dB Quieting Sensitivity 14dBf Frequency Response 30 ~ 15,000Hz, ±3dB Stereo Separation 38dB (1kHz) AM TUNER Frequency Range 530 ~ 1,710kHz (10kHz step) Usable Sensitivity 20µV CD SECTION Frequency Response 20 Hz ~ 20,000Hz, ±3dB Wow & Flutter Below measurable limits Stereo Separation 85dB S/N Ratio (A-weighted) 100dB Dynamic Range 98dB Total Harmonic Distortion 0.01% AUDIO AMPLIFIER Power Output 13W x 4 (20 ~ 20,000Hz, 0.8%THD, 4Ohm) - MAX 50W x 4 Lineout Output Level/Impedance 8V(0dB)/55 Ohm Tone Control Bass +12dB at 80Hz Treble +12dB at 10kHz Loudness +10dB at 100Hz/+6.5dB at 10kHz MEMORY STICK PLAYER SECTION Frequency Response 20Hz ~ 20,000Hz, ±3dB S/N
Pictures:
could you make copies of the english part in the manual i reall need one i would pay you for your time
I dont know, but i sent you a PM anyways....still for sale //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
azngotskills
azngotskills
Dallas, TX
azngotskills
