Rare Beast***ZAPCO 4KW Monster AMP*****
zapman
Zapco C2K-4KW
- 4 Channel, 4 ohms: 4x300 Watts
- 4 Channel, 2 ohms: 4x600 Watts
- Bridged Stereo, 4 ohms: 2x2000 Watts
- Special Order 2 Ohm Version: - Bridged Stereo, 2 ohms:2x2000 Watts
- T.H.D. + Noise:
- Frequency Response: 20Hz
- 20kHz; +0 dB/-0.28 dB
- S/N Ratio: >85dB
- Transient Distortion:
- Slew Rate: >20V/uS
- Damping Factor: >225
- Input Sensitivity: 250mV -16 Volts
- Dimensions: 19.5"L x10.5"W x 7.5"H
- SymbiLink? Balanced Line Technology provides up to 16 volts of balanced input for the cleanest, quietest signal possible
-Dual 1,800 watt power supplies per PC board for surges well in excess of rated output power for SPL use
- Three independent output filtering stages allow full range use as well as bass use in SQ systems
Both Amps are in good condition. They have been sitting in closet for over 3+ years. Bought this for a project but never got to do it. I started to take the shinny part from the rods off to paint it black put never finished it....so two rods have pieces of shinny chrome missing. These are well taken care of amps. I would rate them 8 out of 10
$2000.00 OBO plus shipping
Amp is really heavy around 30-40 pounds
ebay might be your best bet the price is just to high for a first time seller,and from your post you seem to be a busy man so you might not be able to get the amp out im a timely matter witch can caues even more problems
zapman
zapman
Maryland
waylouderthanyo
