Rainbow SLC 265 KICK
butterMilk
BC
Was thinking of picking up a set of these, they seem to get good reviews.
It says that "System has to be used with an 80 Hz (12 dB/Oct.) high pass!"
Thats not the crossover that comes with the speakers?
My amp has no adjustment! It might have some type of high pass already set on it?
My big question. Would it be ok to use them on a stock HU/amp set up?
Mmmmmk. Thanks!
Would it be safe to say that the factory rockford system is already filtering that, in order to not blow speakers that are already there?
Mmmmmk. Thanks!
No, not necessarily. Bottom line is if you want better sound you are probably going to need to replace the deck. You have to figure that those speakers run at 75W rms and your stock system is probably around 22-50w. Your gonna be a lot more satisfied in the end if you get a new deck, external amp, and comp. speakers / sub. This doesnt have to be a very expensive undertaking, but it will probably be more than 450$
Yeah good points! Im just not ready to get a new HU yet. Im kinda of curious what kind of sound i can get with just upgrading the speakers.
Im just hoping I don't kill the speakers before I get a new HU.
If I'm not satisfied with how the speakers sound coming off the stock HU/amp, Ill just run a new amp off my lc6i. And hopefully that has good sound!!
from the owners manual:
ATTENTION: Kick bass component sets are no full range sets. They are designed as satellite sets and
can
not be used without an appropriate subwoofer
Kick-Basses are designed to playback the Kick-Bass frequency range at its best. The Kick-Bass
frequency range starts from 70 Hz and above. Because of this fact Kick-Basses can not play frequencies
below 70 Hz. An amplifier with active high pass of about 80 Hz must be used to drive the Kick-Bass set.
Further you will need an additional subwoofer which is set on low pass of about 80 Hz.
The above mentioned notice is valid when exchanging existing woofers to Kick Bass woofers as well.
The Kick Bass woofers need a burn-in time of about 10 hours to achieve their maximum performance
NOTE: Driving the Kick-Bass sets with full range music signal will cause rattle sound with low bass and
will damage the Kick-Bass woofers in the long-term!
Oh thanks for the heads up. Sorry, what is kick-bass? and uh, satellite set that can't be used without a sub woofer?
Well my first choice for speakers was Unity U61-2 6.5" 2-way Component Speaker System. But they wont ship to canada eh! **** !!!
Then I was about to buy these rainbows, not a good idea.
Any recommendations for some good 6.5 comps in the 350$ price range?
Kick Bass = Kick Drum in a drum set...the loud punchy bass in most songs.....the Rainbow Kicks are designed with emphasis in the 70hz region to accurately reproduce the kick drum frequencies with a steep active cut-off below that. Playing them full range will cause bottoming and make them sound like crap until they die from the voice coil slamming into the back plate.....actually I bet they sound real good with an active midbass/subbass setup
I have the sac465 kicks and they came with a separate hpf that was included. So I have two crossovers per side
the manual for the Rainbow SLC 265.25 Kick does not mention a hp crossover for the Kick, it specifically states an Active x-over high pass at 80hz must be used. The info I referenced earlier was copied and pasted from page 20 of this:
http://rainbow-audio.pl/docs/SLC_21025-23025-26525.pdf
Yup. Guess I should've clarified that I was just putting in my .02 not tring to say you were wrong. Def appears to be solid info. Kinda odd they include a hpf in one set but not another.
that was kinda the point I was making, my feelers aint hurt lol...I posted the link to the manual for the OP's benifit. Are the ones you use impressive?
butterMilk
butterMilk
BC
butterMilk
