I am selling a barely used rainbow I-Paul 4.300 amp. This amp was only used for about 2 weeks. Still has the plastic on the front of the amp. I am only selling because I need money for medical bills. This is an excellent amp. It is missing the 2 little screws that holds the silver plate on the front of the amp. You should be able to get 2 screws from your local hardware store. I am asking $300. Needs to go asap.
Specs below
Its purist design is a genuine highlight in the realm of amplifiers. The Rainbow iPaul series will make fans of functional car HiFi aesthetics hearts beat a little faster. The iPaul is remarkable in its sound, performance, reliability and design as well as its well thought-out remote control concept. An innovative cooling concept with inwardly positioned fan blades, in conjunction with an extravagant housing design, lends it a futuristic flair. With the iPaul series Rainbow satisfies the stringent requirements typical of most car HiFi enthusiasts, impressively combining reliable Rainbow quality with elegant design, consistent ergonomic operability and uncompromising sound standards.
4-Channel
Peak output power
4 x 300 Watt
Output power RMS at 4 Ohm
4 x 90 / 2 x 270 Watt
Output power RMS at 2 Ohm
4 x 140 Watt
Output power RMS at 1 Ohm
Load impedance
4 x 4/2 | 2 x 8/4 Ohm
Total distortion factor (THD+N)
0.04 % @ 100Hz/1W
Signal-to-noise ratio (S/N)
> 95 dB A-weighting
Frequency response at -3 dB
10 - 35.000 Hz
Damping factor at 4 Ohm
> 200
Input sensitivity line input
0.25 - 6 V
Operating voltage
11 - 16 V DC
Input current / Peak input current
71 A
Efficiency
Dimensions (WxDxH)
415x60x250 mm
Weight
5.5 kg
Certification
E11 10R-024083 / CE
Active Controls
High-pass filter
15 - 5.000 Hz, 12 dB/Oct.
Low-pass filter
50 - 5.000 Hz, 12 dB/Oct.
Band-pass filter
Subsonic filter
15 - 500 Hz, 12 dB/Oct.
Bass boost
0 / 6 / 12 dB
Phase shifter
0 - 180°
Remote Control for Phase and Gain included (connecting lead 5 metres)
Specs below
4-Channel
Peak output power
4 x 300 Watt
4 x 140 Watt
Load impedance
0.04 % @ 100Hz/1W
> 95 dB A-weighting
10 - 35.000 Hz
> 200
0.25 - 6 V
Operating voltage
11 - 16 V DC
71 A
Efficiency
Dimensions (WxDxH)
415x60x250 mm
Weight
5.5 kg
Certification
E11 10R-024083 / CE
Active Controls
High-pass filter
Low-pass filter
Band-pass filter
Subsonic filter
Bass boost
0 / 6 / 12 dB
Phase shifter
0 - 180°
