Ok guys I'm installing a full system in my is300, which means i wont be using the stock amp or any stock wiring at all ill be running my own speaker wire and putting everything audio aftermarket.
Now I dont want to bypass my stock amp, I had an s2000 and your suppose to bypass it but i didnt bother and everything worked fine, all i did was wire up the ignition, power, ground, and amp turn on wire and everything worked fine, now i want to do the same exact thing for the is300.
I want a wire harness that plugs into the harness thats in the car and then i can connect the ends of the wires to the wires that come out of my headunit.
The wire harness that i have seen is the 70-8113. Can anyone confirm that this will work and will plug into the harness thats attached to the car. I havent seen many places where you can buy this, does any one know where this can be bought from? A few people have claimed it to work, im just trying to confirm that.
Also most people get the metra tyto-01 but im not going to use my stock amp and also im not spending 100 bucks on a freakin harness thats ridiculous.
thanks in advanced
thanks in advanced
