raamat vs extreme dynamat for the floor.
trunks9_us
which would be better for the floor a bulk pack of extreme dynamat 36sq ft or a roll of raamat 65 sq ft? I hear good things about both now i alrdy own 65 ft of raamat but am trying to decide should i use it on the floor or use it extreme dynamat trying to decide since not sure how much it will be difference since its the floor and all now i will be having dynapad covering all over the floor which is the same as extremeliner. Now the rest of my car alrdy has dynamat extreme on it doors, trunk, rear deck, every where else u know. So someone tell me will it be any difference if i use raamat over dynamat extreme?
I'd give the edge to almost twice as much RAAMmat.
umm i dont understand you so which one is better?
Dynamat Xtreme is slightly better - mostly because of the thicker foil, the adhesives are very similar. Since you are talking about using more RAAMmat to cover the same area, I'm saying the RAAMmat should work better. If you were using the same square footage of both, the DX would work better.
trunks9_us
trunks9_us
college station tx
trunks9_us
