RA-8000.1 question
kpetree
I was bored earlier at work, so I was searching the web and came across this amp. I'm just wondering if anyone has heard or used one of these amps before? I email one of the suppliers for the price list, I'm still waiting on a response. Below are the details of the amp:
RA-8000.1 Super Class D MonoBlock Amplifier
RMS 8000W
Class D Monoblock Power amplifier, one Ohm Stable
RMS OUTPUT Power:
8000WX1CH@1Ohm stable
4800WX1CH@2Ohm
3200WX1CH@4Ohm
Dimensions (LXWXH): 740X280X75mm
Total Weight: 35KG
Basic Information:
FR4 High-End Double PCB
High speed digital circuity
Full Regulated PWM Power Supply
Four Way Protection Circuit
1Ohm Stable
Bridging Synchronization
Variable Low Pass 40Hz-200Hz
Variable Subsonic Filter 20Hz-50Hz
Variable Subwoofer EQ @ 45Hz
Phase Switch 0-180
Remote Dash Mount Low Level Gain Control With Cable
Frequency Response: 15Hz to 150Hz
S/N Ratio: 135 dB
THD: 0.5%
External Fuse: 680A
Full Protection Circuit.
System Distress Indicator
Inputs Sensitivity: 200mv-8v
Platinum Plated Heavy Duty Power & Speaker Terminals
Strapping Capability: Strap two amps together for twice the power
Here are some google pics that I found...
kpetree
kpetree
Littleton, Colorado, United States
Imtjnotu
