"dim" headlights??
chinxtaboi
tx
I cant figure out what is wrong with my headlights, but there bad. They are soo dim when i drive at night i cant barely see the street ahead of me. The problem is when i look at the head lights they seem bright, but when i drive i cant even see. I thought about replacing the lights but im not sure if that would fix the problem. could it be that the headlights are aiming too low? or maybe too high?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
thanks.
yea them seem to be too high. is there any way to adjust the lights aim??
HIDS, i dont have the money for those yet
thanks
theyre the bright white kind, not old yellow ones. i think theyre aiming too high. i dont see how i can adjust the aiming level of the lights though. its a 99 yukon denali.
thanks
thanks
If you look straight down at the lights from above you should see some holes in the radiator support. You should be able to see some phillips head screws (probably aluminum) directly behind the lights. All you have to do is turn them with a screwdriver and it will adjust. One will be for going up and down, and the other will be for going left and right.
Maybe this will help as well:
http://www.gm-trucks.com/forums/lofiversion/index.php/t59615.html
chinxtaboi
chinxtaboi
tx
xtremekustomz
