"Bump" when fan turns on...
phenryiv1
Custom user title
I am in the process of installing a permanent system in my 2003 Nissan Sentra SE-R SpecV. I have installed my HU (Pioneer DEH-P580MH) and I have made some temporary wire runs to the trunk. I say temporary because when I started this I was going to just run a HU and 4 speakers, with a small amp for a sub. As soon as I got into it, I went with a 4-channel amp, comps in the front, and a bigger sub. I HAD run a single 8-gauge pwr cable to the trunk, and for signal I TEMPORARILY ran RCAs through the center of the car (well away from the 12+ wire). I am about to route my 4 gauge permanent power wire and to permanently run my RCAs.
I have a Bazooka in the car while I set up the rest of my system, and when the vehicle's fan turns on or off, I get a slight "bump" through the sub. I have no other engine noise and no system turn-on thump.
Is this most likely a 12V problem (meaning I need to re-route the 12V+) or is it a signal problem (meaning re-route RCAs)? OR could it be that the signal cable is picking up interference where they pass close to the HVAC controls in the dash?
phenryiv1
Custom user title
phenryiv1
Martinsburg, WV
phenryiv1
