Quick VC question....
I couldn't find any diagrams either so I drew some for you.
.jpg
I have 2 Quad 1 ohm subs......need to know what my wiring options are...
I cannot find any schematic that shows this...
Thanks!
Well, you can wire each individual subwoofer to either .25ohm (all coils in parallel), 1ohm (series-parallel) or 4ohm (all coils in series).
You can then wire each subwoofer together in either series or parallel.
So for a .25ohm load at each subwoofer, you could arrive at a .125 final load (subs in paralleled together) or .5ohm (subs together in series)
For the 1ohm load/sub, you could arrive at a .5ohm final load (parallel) or 2ohm load (series)
For the 4ohm/sub wiring, you could arrive at a 2ohm final load (parallel) or 8ohm final load (series)
So your final impedance options are .125ohm, .5ohm, 2ohm, and 8ohm.
This picture should help you some;
ok.....last question...
If I will be running both subs bridged to my amp which is 1 ohm stable for daily, so I would want the 2 ohm option as when it is bridged, the amp will see 1 ohm.....
right //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
A final 2ohm load is exactly that....2ohms. You can't change it. The amp will see a 2ohm load if that's how you wire the subwoofers.
got_focus?
Skeet Skeet Skeet
got_focus?
Loveland, CO
squeak9798
