Quick question on ohm and watts
blackink
If I'm getting a subwoofer that is 1.4 ohms dvc and when I wire it for .7 ohms, what's the formula for calculating the wattage produced by and amplifier that is stable at 1 ohm? Like how much would a saz 1500 produce at .7 ohms?
Also would a stock alt but with big 3 and a batt be enough to power this or should I add another one?
Lastly does the gain setting limit the total wattage produced? Like is setting the gain 50% equal to limiting a 3000 watt amp to only 1500 watts? I'm asking because I want to know how I could limit the total output if I don't feel my car's electricals can currently handle the full power.
Thanks
There is no straight formula, but it's usually linear. ex. 1000w @ 2 ohm, 2000w @ 1 ohm, would then be something like 2250 @ 0.75 ohm. This is just an estimate, unless the manufacturer specifically states what the amplifier will do at that impedance, you can not know for sure (without bench testing).
Assuming that amp is 1500w, a stock alt with 1 batt is kind of wimpy, you'll have voltage dips, a second battery would be better.
The gain does limit the output but not in the way you think. 100% gain does not mean 100% power. You can use it to limit the amp like you want, but you need to do some more research on how the gain works. I recommend this site: Basic Car Audio Electronics
blackink
blackink
Cali
bubbagumper6
