Quick question about fiberglass
I know,but i was saying could i add another layer once the first layer is dry or can you only add layers when the first layer is still wet?
to answer you question.
YES, you cna add a layer after the first is cured //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thank You very much //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
if your using waxed resin, scuff the surface b4 adding any extra layers or else the second layer wont bond and will sit on top and possibly come off, if your using a laminating resin then your fine
do in a cool envir, if doing it in the sun, the resin dries fast and you dont want to add layers to air bubbles
CJL
CJL
oZone
Nexson
