Quick Q
Just like they are in that picture you have in your first post //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Essentially what's happening is you have two sets of two speakers. Wire each pair of speakers in series (for two 16ohm loads), then wire those two pair of speakers in parallel with each other for a final 8ohm load.
So...just do it like the picture you have in your first post in this thread. That is, assuming, you have four SVC 8ohm speakers.
thats what i thought i just had to make sure since i dont wanna wreck the speakers by giving them a 2 ohm load or something.
Thanks squeak your a total life saver!!! squeak ftw
What Squeak said ... I was too tired last night to find a diagram //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
You could also wire each pair of speakers in parallel for two 4 ohm loads, then wire the pairs in series for an 8 ohm load ...
feel left out? well your still cool jmac dont worry about it ! its all said and done your advice is always helpfull thanks agian:)
thats what i thought i just had to make sure since i dont wanna wreck the speakers by giving them a 2 ohm load or something.Thanks squeak your a total life saver!!! squeak ftw
Your not going to hurt the speakers.. you want to wire your speakers to match your amp, typically 2 or 4 ohm. If you wire it to 8 your not going to get anywhere near the output on your amp that you should be.
Crown_amps
Banned
Crown_amps
British Columbia
hoaxci5
